The gasket change seems to have cured the P0171 and P0174 codes (mixture too lean on bank 1 and bank 3). This was diagnosed as a MAF sensor issue but I had seen someone get these errors after incorrectly installed gaskets. So if there was an air leak through my old, hardened gasket mimicking a PCV leak, the new gasket would have sealed the air leak and brought back normal operating conditions.
