Originally Posted By: JamesBond
Do the horn and cruise buttons work?
I had a 1997 voyager that had the airbag come on around 2013, I called the dealer and they said it was covered under a recall. Got a new clock spring and a bunch of greasy fingerprints installed for free.
Google it up, it's not quite a normal recall, where they replace every clock spring, they only replace it if it fails. If the airbag light is on and other buttons on the wheel don't work, it's probably failed.
I talked to the mechanic about the airbag light, he said it doesn't matter for the inspection, so it goes over tomorrow. I've been searching and found several u-tube videos, so will go from there. If I fix it, I'll report back.
