This came off the '12 Ram 1500 with a 5.7 Hemi. Yes I acknowledge that this is the wrong filter. But the only difference is that the bypass pressure is 6PSI higher compared to a NG 7899.
The oil I used was Chevron Supreme 5W-20. Put more Chevron Supreme back in with a M1-210 filter. Most likely I'll use that filter for 2 OCI. ~16000KM.
I forgot to take a picture of inside the can but there was nothing inside. I guess this truck is pretty clean.
ADBV definitely worked because when it wouldn't even move until I pushed it. If you look at the base plate where the ADBV sat there's no oil on it.
