TIRE QUESTION
Ankeny, IA
Hey all, quick question. Looking at a set of wheels from a 2014 Mustang GT for my 1994. They are 19", currently I have 18" Really simple, will they fit? Bolt pattern appears to be the same from what i can see. TIA!
They *may* fit, but you should check the offset first. In 2003 Ford changed the offset significantly in the Panther platform (Crown Vic, etc) and wheels from an '03+ will not fit a 1994 without spacers. Not sure if this applies to Mustangs.
Pretty sure they made that change on everything that used 5x4.5 except the Ranger at some point in the mid 00s.
Looks like the wheels for '94 Mustang have lower offset compared to '14.
So, if you put them on your '94, they might rub on the inside, depending on how much room there is left. Might need spacers.
