Originally Posted By: Shannow
Originally Posted By: turtlevette
Drain all coolant, flush, then let air dry. Fill radiator with atf or motor oil. See if the heat transfer capability of oil is good enough to properly cool the engine.
Like that one...it was one of my imaginary "dry sump" set ups when I was 19-20...tapping the Holden 6 oil pump discarge into the block, and a crank (snout) mounted pump from the water pump to the galleries.
starting turtlevette's setup in cold weather.....
