I have an 02 Mazda Protege with 228k miles.
Recently it has started to consume oil. It has been about 1/4 qt for about 500 miles for the past few months. Body is rusted, so I am just trying to keep it alive at this point.
Manual calls for using 5w30. But I was wondering if I should switch to a higher weight since it is older and has started to consume oil.
Other info..
- automatic, so it is not revving anywhere near redline
- putting about 27k per year on it
- Live in Maryland
- OCI has been about every 4000 miles with whatever is the least expensive full synthetic that Advance Auto has
- Replaced radiator and water pump in January
- not sure about what the daily drive is like, it is actually my daughter's car. She does seem to drive a lot in the Baltimore/DC corridor. So most likely lots of stop and go.
- I use seafoam through the brake line every 30k miles. But I have NOT used it in the crankcase
- use a bottle of techron in the gas tank every oil change
So, any advice on easy solutions to reducing the oil consumption and increasing the life of the engine?
Other info..
- Live in Maryland
