Keep an open mind about tp bypass filters.
I ran one on my oil and one on my coolant on my truck for four years before my truck was totaled a few months ago. They do not filter out additives and it will not dissolve in water. The TP does NOT come apart and clog up your motor. If you worry about that you could put a filter (like the magnefine) after the bypass filter.
I changed the toilet paper element on my coolant filter every six thousand miles. I’m sure that I could have change the element on a yearly basis but I’m kind of anal. My coolant was better that factory new. It was major overkill. I installed it to prove that the tp could function as a coolant filter and would not dissolve in water. After four years, I guess I proved my point.
I changed the tp element on my oil bypass filter every three thousand miles. One TP roll and a quart of oil is a pretty cheap oil change. The one quart of oil per change will keep the additives up.
Gary Allan always said that it would make your motor last longer than the rest of the car. He was right. My truck has the best motor in salvage yard.
