I had to get a new Ecotec oil filter with the cap PF458G, and I got a NOS Purflux, with the zig-zag pleats. The date code is 11V25OCT01-08
Is this old filter safe to use? The media is an orange color now, rather dark, but there is no metal to rust.
Is it October 25, 2001, or is it October 1, 2008?
If the filter itself isn't safe to use, I have a newer Hengst cartridge (PF457G). I really just needed the gasket and cap, and the cap isn't a wear item. The PF457G doesn't come with a gasket. The Purflux doesn't smell any worse than the Hengst.
And while we're at it, how do you decode Hengst date codes? It's either 40DOJ or 12-605-566.
Interestingly, the plastic end caps are slightly different material. Purflux uses PA66-GF20, while Hengst uses PA6-GF30
