Last year I had a small leak on my Olds power steering pump using about an ounce a month. Pump has been noisy for years. Over the winter I had one of those O'Reilly Christmas coupons, so I bought some of the Lucas power steering fluid with stop leak, and put the whole bottle in. Pump did quieten down lots, and it did slow the leak to almost nothing. My son had to drive my car the other day, and told me that the power steering was noisy, and told me to check the level. I had checked it the day before, so I knew it was fine. I was just accustomed to hearing the whine of the PS pump, so the noisy did not bother me as much.
Went down to Walmart, and I bought a quart of the SuperTech power steering fluid with stop leak. Swung by Harbor Freight, and bought one of those oil suction guns because I had a 25% off coupon, and a turkey baster is just too slow. Pulled out approximately 8 oz. of fluid from the reservoir, and then put in the SuperTech fluid. Wow, the pump sounds like a new one, and lots better than some rebuilt junk pumps I have bought previously.
All this got me thinking, so I read the back of the SuperTech bottle very carefully. It says it's recommended for top offs, but not recommended for a full change. I wonder what in the world is in the SuperTech to quieten down a pump that much? Never ever had fluid to quieten a pump down to the degree that the SuperTech did. I am impressed with the concoction.
SuperTech Power Steering Fluid with stop leak
