So if i'm correct double clutching is :
Press clutch in and shift into neutral
Touch the throttle to raise the revs
Press plutch in again and shift into gear normally.
A while ago i posted a question on why does my gearbox have a slight rasping sound when downshiftinf rom 3rd to 2nd and somebody suggested double clutching, it should help right since what you are doing is essentially rev matching so the both gears have the same speed?
Also i might ditch the idea of using Ford B0 GL4 75w90 in my Gearbox ( specs 80w ) and going with Castrol GL-4 80w EP gear oil
