Originally Posted By: nickolas84
Originally Posted By: dgunay
Please check this post, I hope this helps!
http://www.ft86club.com/forums/showthread.php?s=38c40c695918e32732aa66d138dc2d98&t=91820
This post makes no sense...he had higher oil temps with the thinner oil, which should not happen under same conditions. Propably he run the engine harder or outside temp was higher when he had the 20 grade oil in. Having said that, 130C is close to the limit you want to run any engine oil.
Racing the GT86-BRZ with the stock 20 grade oil has been done in bitog and with great results. The same user even made the comparison with oil analysis with a 30 grade oil and the results were in favor of the stock 20 grade. You can find it here
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3305134/1
That car is less than 4000 miles and you really show that as a proof? No thanks. Of course, the car is breaking in, so the first sample is worse than the second one, and I bet the third sample will be better. So the results were in favor of
newer oil, it's not related to viscosity.
If you read the article that I sent in the previous post, he clearly states:
Quote:
The blue is the 0W20, and the yellow is the 5W30. You can see pretty clearly how the 5W30 helped keep oil pressures higher as temperatures increased, but didn't really give us abnormally high pressures at lower temperatures. Both tests were run on track here at the Motorsport Ranch, with
ambient temperatures around 85-90F.
I really don't understand why you think that the test is biased.
If you really think thinner oil is better for hot weather and extreme conditions, can you please explain why do some manufacturers require thicker oil for severe conditions instead of lighter weight?
And let me tell you, 130c is not close to the limit, as long as you have sufficient oil pressure, you are good to go. Many people see 300F - 150C on track without oil cooler. I admit I wouldn't feel comfortable if it's over 140 but I've seen 148-150C's in the past, no problem so far.
