Long story short, the shutoff valve on the output of my water heater wouldn't open back up after I closed it. I have copper pipes so naturally it's all sweat fittings. After dickering for awhile I decided to try to replace it myself (haven't worked with sweat fittings before). So I cut the pipe above and below the existing valve and replaced with a new ball valve joined with lengths of pipe and couplings. The sweat fitting closest to the water heater is weeping and after retrying 4 times I think I might have to start over. I'm thinking I may not have sanded the existing pipe well enough or something.
So now, going from the top of the water heater on up, here's what we have now:
preexisting pipe -> coupling -> new pipe -> new valve -> new pipe -> coupling -> existing pipe.
If I cut off the problem coupling I'll have to use 2 couplings plus a short section of new pipe and it'll wind up as:
preexisting pipe -> coupling -> new pipe -> coupling -> new pipe -> new valve -> new pipe -> coupling -> existing pipe.
Is that the right thing to do? Any suggestions for getting this last connection to seal?
