Originally Posted By: whip
Thanks, I'll check out the duragloss next time.
Another question, is there anything I can do with the can of cleaner wax that wasn't very good? I'd hate to just throw it away.
I am the same way. I have lots of different car care products which I tried at some point but no longer use for whatever reason, and now they just sit on the shelf and collect dust mostly. There is a bottle of Meg's Cleaner Wax up there too.
If I paid money for it, and it does what it is supposed to do, I won't just throw it away. So for me, the best use of such products is to save them for the next time a friend or family member asks you for a can or this or a bottle of that...or worse, asks you to wash/wax their vehicle yourself in the hopes you can perform a miracle on their POS and make it look like yours somehow.
In those instances, I will go to the "no longer used" shelf and give the person whatever they asked for from that shelf and tell them "this is some good stuff, it'll work for what you are looking for." Which isn't a lie, whatever it is will work for them, just maybe not as well as the other products I do use but which I will not give away.
And with respects to the Meg's Cleaner Wax, I have found it to be a good option in varying different scenarios for which I wouldn't otherwise want to use some of my "good stuff" due to limited amount or prep work required:
1) as someone else already mentioned, protecting a set of wheels on a vehicle which has not previously had its wheels waxed for protection, e.g. a used car is added to the family, and its previous owner barely kept the car washed, much less wax on the wheels.
2) lowest portions of vertical body panels on daily drivers.
Let's face it, no one is going to be spending any time up close and personal with the bottom half of my car's fenders and doors, not even me. So those are the areas of paint which are most likely to have the least quality paint prep applied before any yearly/semi-annual polish and wax session. So if it is really hot and I am really tired and my back really hurts, I might just stop polishing out the CC swirls about half-way down the vertical body panels and use Meg's Cleaner Wax for the remaining paint surfaces.
3) temporarily protecting any areas which have had their normal protection removed for whatever reason and will have to wait a while before I can devote the time/energy to doing things right to get them back into the fold.
For example, if I had to use some bug & tar cleaner on an area of the hood to remove the remnants of a failed plasti-diped stripe attempt, that area would be sans wax protection as a result. But if I introduced any new swirls into the CC while removing the plasti-dip, I would want to polish those out before applying my normal wax of choice.
However, if it's one of the summer months here in Texas, I might be unwilling to break out the polisher and spend time in my garage removing CC swirls, preferring to wait until cooler weather sets in. So in that scenario, I would just hit the area with some Meg's Cleaner Wax to get something in place and protecting it while I waited for October or November to draw near.
