Originally Posted By: Ws6
Originally Posted By: billt460
Originally Posted By: hatt
You're stuck on issues from 1965.
Here is more to help you with your "education". "Stuck on issues from 1965". Yeah, right. Wake up.
https://warisboring.com/the-armys-main-r...c76b#.mvbg6bbkx
WANAT was an example of a lot of things gone wrong. That said, one of the CRITICISMS is about a guy who ran 12 mags through a rifle, firing on average a round every 4 seconds (you can bet it was way more than that, and way less, depending, during that 1.5 hours).
You try that with an M14 under similar conditions. Or any rifle. Pick one.
Like I said, steeped in politics. You missed all the firefights in which not a single problem occurred, when soldiers used better mags and maintained the weapons well, even though some weapons were used at least as hard as Wanat saw. But like I said, it's all to push an agenda. And yet USASOC still loves the M4 type, and as you said, they can have whatever.
They would have never had enough ammo to run an M14 that hard in combat. 5.56 platforms bring a lot more ammo to the fight. And then get a negative mark because guns get hot.
