Post your latest oil change
Friends 2011 Subaru Legacy 3.6L
Out: Whatever dealership uses and a Subaru filter.
In: NAPA Full Syn. (7 quarts!) and a Purolator PL-14459.
Car has close to 50K, interval was about 5K.
Parents Tank
1989 Chevy Suburban - 350 V8 - TBI Auto
Mileage on vehicle - 300k/400k ish - real mileage unknown
OCI - 5,156 miles and 7 Months
Out - PYB 5w30/10w30 mix - and Casite CF279 filter
In - Formula Shell conv - 5w30 and Casite CF279 filter
2009 Ford Focus SE Coupe 122k miles
In: Chevron Supreme 5w20, Motorcraft FL-910s
Out: Chevron Supreme 5w20, Motorcraft FL-910s
'12 Accord 4 cyl
Oil run 1/30/16-7/17/16, a couple of hundred miles past 15% MM and a little over 8K.
Out: TGMO 0W-20 SM and Fram Ultra
In: HGMO 0W-20 SM and Fram Ultra
Yeah, I know that both Fram and Honda would say that the Ultra would have been good for another OCI, but I can't bring myself not to change a five buck filter while I've got the car up.
I will likely do a convenience change in late December when we catch a nice day. This OCI should be around 20% MM by then and I'd like to avoid a forced change in either Jan or Feb when the weather is bound to be colder.
My Ford Taurus
valvoline 5w30 semi syn out
valvoline 5w30 full syn in
Motorcraft FL400 filter
out patrolling the tall corn in Iowa all next week on sales calls
2004 Lexus RX330 - 130.5k
Out: Mobil 1 EP 5w-30, Wix filter, 5500 miles
In: Mobil 1 EP 5w-30, Toyota oil filter
2012 Honda Civic - 83k
Out: Mobil 1 EP 0w-20, Honda oil filter, 7200 miles
In: Mobil 1 EP 0w-20, Honda oil filter
Out: Amsoil XL 5w-30 at 7500 miles with a Motorcraft FL-900S filter.
In: Pennzoil Platinum 5w-30 with a Performax PO-21 shop filter from work.
Probably going to run it 7500 miles as well, both are getting analyzed to see which is better for my engine. I like Amsoil, but hate the hassle of obtaining it when I can walk into O'Reillys and buy PP off the shelf 7 days a week and not have to pay for and wait for shipping. So unless Amsoil blows the PP out of the water in wear numbers, TBN, and other factors, I will probably just stick with PP from here on. We'll see in a few months from now!
2009 Highlander Limited 4wd
Out: Mobil Super conventional 5-30, OEM filter - 4000 miles on the oil
In: PP 5-30, OEM filter
First time using synthetic on this car, after 60k miles using MS 5-30 OCI: 4-5k miles
Is so early talk about oil consuption but the engine is noticable more quite and easier when starting up.
2015 Ford F-250 Platinum FX4 6.7L Powerstroke
OCI = 6,860 miles (2 months)
Out:
Mobil Delvac 1 ESP 5W-40 and CarQuest Blue made by Affinia (WIX)
In:
Chevron Delo 400 XLE 10W-30 and CarQuest Blue made by Clarcor (Baldwin)
2013 Jeep Grand Cherokee 5.7L
OCI 5k miles
Out: Mobil 1 5w20
In: Mobil 1 5w20
Old filter: puro pure one
New filter: Fram Ultra XG2
2011 Nissan Rogue 100,096KM - Stickered it for 8,000KM.
Changed air filter, topped up washer fluid and coolant.
Manual calls for 4 and 7/8ths of a quart but I had to put 5.5 for it to read full.
Out: Mystery Oil / Pegasus PF737 Filter
In: QSGB 5W-30 / Napa Gold 1358
2008 Honda Fit: 5179 miles
Out: Peak 5W-20 / Purolator filter
In: Smitty's: Super S Multi-Flo 5W-20 / Fram Extra Guard
2007 Saturn Vue V6
110k on odometer
6k on oil
Out: Castrol GTX High Mileage 5W-20, Purolator PureONE PL14610
In: Formula Shell 5W-20, Purolator PureONE PL14610
Did two oil changes today.
85 rx7 2k miles on Castrol GTX 10w40. It was a quart low and I had used my castrol 10w40 as top off on another car so I went ahead and changed it to M1 15w50 for the hot weather. Left the STP XL oil filter in place
2002 Pontiac Grand prix 3.1. This engine seems to be picky about oils. Both me and my girlfriend swear we can tell it feels less peppy on some brands of oil. She mentions it without even knowing what oil was used at oil change. Some shop did some work on her car and put in whatever oil. This engine really seems to like a little moly. Pennzoil, QS, and supertech seem to make this car feel most normal.
Out: mystery oil, microgard filter
In: Supertech HM 5w30 and a Prime guard filter
2004 Ford Ranger 4.0L V6. 155465 miles on vehicle. 5033 miles on oil and filter.
Out: MC Premium Synthetic Blend 5W30; WIX 51372
In: Quaker State Advanced Durability 10W30; Fram TG2
After setting for 12 hours, pulled the filter and there was no oil in the galleries above the oil filter.
Re-installed the filter and ran the engine 2 minutes at the most. Pulled the filter and recovered 4 oz. plus of oil from the galleries. Conclusion: ADBV function is a fail.
'95 BMW 318i
159K car, a little over 4K oil. Oil run 4/17/16-7/24/16
Out: Defy 10W-40, Mahle filter
In: Delvac 1300 15W-40, Mahle filter
The Delvac Super has much higher HTHS viscosity than did the Defy, so it'll be interesting to see what the impact will be on fuel economy.
