I'm NE of Moscow Russia, have driven 16K mi this summer. Alaska to Halifax, Antwerp to Mongolia, now returning to W Europe. I run Delvac 1 75W90 in diffs and portal hubs.
Yesterday I leaked 300ml out of 700 fron the inside (CV to portal) seal left front. I refilled 300 last night plus about 55ml today while running. I am refilling with Penrite Full Syn 75W90.
The last 2 checks over 140mi no leakage. The seal has no seepage.
I hypothesize the Penrite has a higher ester/PAO ratio and the seal has swelled shut. I of course have spare seals, 3 actually but it is quite a job going thru the disk brake, hub, gears and bearings to get to it. There is a MB shop in Moscow just for modern Mogs about 200mi away.
I may switch on my next change to highest ester Redline, it does have 90K mi on the truck.
Charlie
Charlie
