Best outboard oil for 10% ethanol gas ...
Kalifornia Kollective
Of the brands readily available at the usual stores like WM, AZ, PepBoys, etc. Which outboard oil have you'all found to be the best?
Highest quality TC-W3 that exceeds minimum specs and keeps the top end clean while lubing well.
Any spec'd for both TC-W3 and API-TC ??
Although I don't do boats. I have had excellent luck with Mercury Quicksilver at Walmart. I have used their multi-use two stroke oil and have over 3,000 miles on a two stroke ATV without any issues and no reason for a rebuild. All ethanol gas. That's a good endorsement to me.
Cool
I've used Pennzoil in my Bayliner/Force 85 OB for 26 of the last 28 years. Originally I used only the Force brand oil. I did just purchase a gallon of Quicksilver; but have not used it yet.
