New timing belt water pump, tensioner and pulley bearing installed on an 06 Kia Spectra 2.0L. Went with Conti-Tech kit which uses GMB bearings. At first I set the tension too tight, started it up and it whined a bit, I ran it like this for only a couple of minutes. Was able to pop only the top cover off and re-tension it, but when I back it off to a level at which i feel comfortable with, it still makes a bit of a whine (albeit much less than the first time). I don't remember any whine on this engine, and comparing it to a running parts car that has never had a timing belt changed, it was also louder than it. I did notice a little bit of belt rubbed off on the tensioner, but really not too much. If I back it off any further the tensioner will have barely any resistance to the belt, and I'm not sure if this is okay. As it is I can turn the tensioner by hand with only a little bit of friction on the belt. The vehicle drives fine otherwise.
First time I have ever had trouble with this kind of thing, although I am used to Honda's which set tension on their own with the spring and hook mechanisms. Hope I didn't damage the bearings on either the tensioner or the bottom roller, as I really dont want to take this all apart again.
On this thing you have to set it yourself with a 5mm allen. Half way through 06 Model year Hyundai changed the design to a system that guides you a little more.
Here is the guide I followed for reference. Axle Addicts - DIY Hyundai
Thanks for your help, really need to get this right so this car can last as I have just done a ton of other work to it.
