I have similar experience with gear oil changes. The first change yields lots of fine metal debris, to where the oil looks like metallic paint. Subsequent changes - not so much. I believe diff and transfer case fluid should be changed early - like 5K - to get the break-in debris out. Then go with a schedule you can live with, somewhere between 30K and 100K intervals.
