The instructions I have says it takes 3.75 quarts of HCF-2 to refill. I
measured the amount in it with a dowel before draining and it took 8 Inches
of dowel before reaching the oil level. I didn't measure what came out
(which was rather dark with 50K on it) but in refilling it took all four
quarts to nearly, but not quite, reach the level that it had originally.
I'm not at all sure it had the correct amount to begin with as the transmission
was worked on at about 15K and replenished then.
Is there any info on how high the fluid should be when measuring with a
dowel? It only has a rubber plug without a dip stick.
