Does the Ecotec's cartridge filter cap need to be replaced regularly/periodically? The one I'm dealing with is a Saturn L-series 2.2 Ecotec, and the cap nut is slightly rounded. Other than that, how do you know when it's time to replace the cap?
I ask because the PF457G doesn't come with an O-ring, but the PF458G is the same filter but with the O-ring and the cap. The 458 is only a few dollars more than the 457. It's a good filter, being made by Hengst, but shouldn't they always include the ring?
And how often should I use a 458G instead of the 457G? Right now, I'm thinking of using a PF458G now, and then a PF457G from next OCI on, with an occasional Mann HU 6007x in between (Mann includes the O-ring, and the 6007x is made in Spain).
