ON the Focus in the sig, I recently replaced the interior dome light with a red LED to:
1) reduce eye fatigue when opening the door
2) try something different, cause it was cheap
Anyway, since replacing it a few weeks ago, last night when returning from purchasing groceries, I noticed that when it's in the "door" position (and doors closed), it gives off a very small amount of light. Only when in the "off" position, is it truly "off".
The dome light operates on a dimming circuit. At first I was concerned that it was killing my battery when the car is off. Then I realized that it's probably picking up the tiny current that it's fed, when it's supposed to be off.
I never noticed this when using the traditional style of incandescent bulb in that place. Then again, that bulb requires more power to run and generates considerably more heat!
Should I be worried? or am I concerned for nothing?
thanks in advance
thanks in advance
