Originally Posted By: Wolf359
Originally Posted By: Superflop
Lol using shell @.20 cents more is still cheaper than techRon each fill. Also you don't need detergents that often. Anyway berrymans injector cleaner with pea is like 3 bucks at oreilly's and only needs done every other oil change.
In theory, you don't need any extra. The EPA mandates a minimum amount in all gasoline. I never worried about it and never used Techron. Ran close to 200k on a car with just regular cheap gas at whatever station was cheapest. Never had a problem, still on original injectors.
And b12 is within $4 bucks easily!!!
Far better than seafoam in my opinion.
I just add my own concoction of additives from time to time with no bad effects.
