Was told to check on a shifter driver that said his truck overheated. The driver said he happened to look at the temp gauge being pegged and shut the truck off immediately.
The bottom radiator hose blew out, a whole lot of coolant escaped and the poor 6.7 Cummins over heated to oblivion. The stop engine light and the warning buzzer didn't come on plus this truck is supposed to derate the power by means of it's electronic throttle control in this scenario which it didn't.
There is a low coolant sensor in the radiator which failed and the heavy rain hid the leak from showing on the yard.
I ordered a low coolant sensor, put a new hose on it, filled it back up with coolant and no problems, so far anyhow.
