Originally Posted By: tomky
I have been using some of the Valvoline Moly grease but was told it was a bad choice for bearings. Would you continue using it or switch to say the Mystik JT 0? If I switch will there be any problems caused by mixing?
I've never used moly loaded grease nor have i researched it, so I don't know about using it in bearings of any kind.
My understanding is that mixing Lithium Complex based grease with a Polyurea base is bad news, but switching from one LC grease to another is okay. Maybe some additive clash makes it less than ideal but you will get it all swapped out before long. If your moly grease is Lithium Complex based, you can switch to Crimson or Mystik without trouble.
In the last few years, I've tried Shell Gadus, Valvoline Crimson, Mystik and now Delvac Xtreme. Mystik is fabulous but I can acquire the Delvac at truckstops for a fair price and seems to work great. Haven't noticed any issues when switching brands and I don't bother trying to flush out the old grease (it would require a mess of grease).
