What is this shaking coming from?!
Denver, CO
It's been doing this off and on for awhile, I just had new tires put on, a new brakes and rotors, new sway bar bracket and links, as well as new front struts the other day. 2005 Chevy Malibu Maxx. Only does it on the driver side and really at high speeds. I can feel the vibration start in the wheel and it get much more pronounced when I brake.
https://youtu.be/C688-PxjrKk
I did not check the runout. I'll check the lug nuts but it's been doing it for awhile, but only intermittently.
I would rotate the tires to see if the vibration changes. Otherwise, I would inspect the entire front suspension (especially the control arm bushings) and go from there.
Well now I've had the driver side control arm and the ball joint replaced.....atill doing the same thing. Although it seems different, like it's tighter or something. Does anyone have any ideas? I can't keep throwing money at this thing.
