This is a fairly common problem, caused by the timing gear actuator not stopping in the correct position. The gear assembly then rattles loudly for about 1-2 seconds on cold starts. My 2010 Vibe started doing it last summer, out of warranty.
My question is, basically, will this damage the engine if I don't get it fixed?
There's a lot of experience with both ownership and repair on this site, so I'm hoping somebody can answer. The Vibe and Toyota sites mostly say "my engine rattled and I got it fixed under warranty," but I couldn't find anything about damage or failures.
Last summer, I took it to the dealership I've used for recalls and other work. I gave them printouts of the GM and Toyota TSBs, played a recording of the noise, and left the car overnight, but they couldn't hear anything. The problem is, it happens only on the first start of the day, and then sometimes again if the car sits for most of the day after being driven.
I need to take the car in for another recall, and I'm debating whether I should arrange to leave it overnight and have them check again. If they had diagnosed the noise last year, they could have charged me a lot to fix it. This isn't a repair I'm confident doing myself, and I can live with the noise if it doesn't hurt anything.
Thanks to everyone for your input.
