OK, a bunch of stuff wrong in these posts:
1) Yes, Dodge does specify 50/80 psi for at least one of the models Dodge made that year. I assume that M_O_M (Motor_Oil_Madman) looked it up - as he also noted Dodge specifies 45 psi if the vehicle if empty.
2) It's a specification. Not a recommendation. It's like the viscosity of the oil for the engine. You MIGHT be able to get away with using something different, but it is what the vehicle manufacturer specifies, so don't dismiss it lightly.
3) It varies, but as a general rule, vehicle manufacturers specify enough pressure to handle the load on the tire - plus a bit more pressure. Dodge seems to be the only one who didn't learn their lesson during the Ford/Firestone incident some 16 years back - that tire pressures have to be specified to carry at least 15% more than the minimum. I would be careful deviating from their specification.
4) In vehicle dynamics, tire pressure affects the front to rear balance, and vehicle manufacturers tests at the pressures they specify. So while Dodge specifies one set of pressures for a fully loaded condition and a different set of pressures for an empty vehicle MOM is saying he wants to use a third set that is biased the opposite direction. The problem here is that unless you burn off a set of tires trying to establish that a particular set of pressures works, you'll never know until it is too late.
5) Yes, higher pressures makes the steering wheel easier to turn. So does more power steering. That doesn't make it right.
6) And lastly, DO NOT USE THE CHARTS to set pressure. Those are MINIMUMS, not recommendations.
7) DO NOT DO THE CHALK TEST. That test is predicated on the idea that the tire manufacturer designs his tires to handle the load AND get even wear at that combination - and that is just plain wrong. While tire manufacturers spend quite a bit of time trying to get their tires to wear evenly, they don't always succeed, but more importantly, they try to get the tires to wear evenly REGARDLESS of pressure - so you could get a false reading if you do the test.
So my personal recommendation would be that IF you want to use 60 psi in the front for ease of steering reasons, then put 60 psi in the rear when empty, and 80 psi when loaded. That way you are at least mimicking the vehicle manufacturers specs.
