I`m not that concerned with the magnet. On a Road Star they have 3 oil bolts one for the gear oil, one kind of mounted on the side between the frame that has a larger head on it that is a bit of struggle to get a wrench on. A plug with a smaller head would make it easier to apply a wrench. That is the one I`m most concerned about. And a third plug on the bottom side which is easy to get at as long as you aren`t raised up on a jack blocking its access. If I park the cycle front wheel on a 2x10 board I can get to all of them. I sprayed them with some red paint when I did my first oil change to make them easier to spot when I did future changes.On Ebay some of the cheaper oil drain plugs are the anodized aluminum plugs in colors, those are what I`m considering.Just was wondering weather they hold up ok and are compatible ?
