It makes absolutely no difference. The tanks are underground where the temperature and humidity are fairly constant. There are some people who still believe the myth that you should fill up when it's cool outside, but that's simply nonsense. Any expansion or contraction of gasoline due to temperature shifts, for the small amount that is in the tank of a vehicle, is so minuscule as to be nonexistent. Combine that with the minuscule expansion and contraction that will take place in the tank of the vehicle, and it makes the idea of filling up in the morning to try to get more from the pump because of the outside ambient air temperature another ridiculous myth.
