Mantooth
Thread starter
Originally Posted By: Mantooth
Installed the filter, primed the fuel line and fired her up. She ran like a top. Although, I did notice it is running hotter than it should be. Temp guage was half way between normal and hot. Plan on checking the coolant level tomorrow as I head out to work. Guessing the coolant is original too.
Sounds to me like the screen is clogged.
Did you check the radiator for grass clippings/ dandelion seeds?
Later model L and M Kubotas have 1 or 2 screens that protect the radiator from debris. The old M should have at least 1.
A coolant exchange sounds like a good idea though.
Where exactly is the screen(s)? I haven't come across any.
Thanks
Edit time passed.
Are you talking about the engine shroud?
Thanks
Edit time passed.
