Originally Posted By: HTSS_TR
Same for Honda S2000. Some had an S2000 with cable and bought another newer model with throttle-by-wire, he hated it.
Same for my Barchetta. Cable always feel more snappy than throttle by wire, the feeling of having the throttle wide open in an instant and the noise it produced is not comparable with some throttle by wire butterfly, even if performances are identical, it just doesn't feel the same. Plus the higher you rev the engine, the lighter the pedal...definitely doesn't feel the same.
On the plus side, you can argue that throttle by wire is a bit more delicate and less "bumpy", but I guess that also depends on the electronics, and isn't an issue on a motorcycle.
