I am looking to pick out the best all in one CLP and have a bunch of questions.
1. It seems there are petroleum based and synthetic based. Is there a particular reason for choosing one over the other or is it just different methods for the same goal and not a critical difference? Any "can't switch between them back and forth without fully cleaning the old stuff off" truth?
2. I see mentions of certain chemicals to definitely avoid. For instance Teflon (PTFE) (with heat releases poisonous gas) and anything with chlorine or chlorinated chemicals (with heat they release gases that can weaken metal). Are these valid concerns? Are there any other chemical to avoid?
3. Aerosol vs liquid. Prederence or any difference is the way it works from the propellants? Seems some say liquids line better and aerosols clean better.
4. Obviously I would also like something that can be used on the entire gun (metal, plastic, maybe even wood although my guns don't have wood) is "safe" for skin, the environment, etc and doesn't stink up the whole house as I have to clean indoors. So far I have tried Breakfree CLP which honesty has a very mild smell (which shocked me because being petroleum based I thought it would stink) which I don't mind but it does contain Teflon. I also tried Ballistol which seems to fit all the criteria except the scent is very strong. People say they even have drank it.
Any other suggestions. I think I will try G96 gun treatment next. Supposed to have a very mild scent and be good.
