Been noticing something unusual for the past few days with my Grand Marquis. I monitor coolant temperature with a ScanGauge-II, and granted the weather is pretty hot - 130+ F - I'm beginning to think my fan motor might be on its way out.
In stock form with a 190 F thermostat, the high speed function would kick in when coolant temperature hit 212 F. As it stands, I'm running a 180 F thermostat with the EEC programmed for it. Although the low speed function is running most of the time, I'm seeing crazy figures like 218 F with the AC clutch engaged. If I'm stuck in traffic, I sometimes turn the AC off and coolant temperature starts dropping at a snail's phase. At 75 MPH on the freeway, 216 F is the average coolant temperature and I haven't heard that wind tunnel noise when the fan kicks into high - not even when the AC is on.
I've checked the relay, which is fine. I'm going to wire it directly and see if the fan works on high speed. Just wondering if anyone has any other thoughts. Everything in the cooling system, except the fan, was replaced when I built the motor.
