Originally Posted By: Kuato
Originally Posted By: Doog
Ok so my new Toyota takes 0w20........I have Toyota care which they will use 0w20 TGMO (which is a blend if I am not mistaken)...but all 3 other 2GR-FE engines I have had have been flawless using PP 5w30.
Should I switch it to 5w30? This is going to drive me nuts......
The F150 gets 5w30, specified 5w20.
The reasoning is three fold:
1) Ford just went to 5w30 from 5w20 in the 6.2 gasser in the HD pickups, so obviously a 20 weight isn't protecting like it should.
2) Ford Mustang with 5.0 specified for up to 5w50 in the track pack - same oiling system as the truck version, so no oil circulation issues going heavier.
and 3) Toyota itself specifies 20 weight for most applications, but in those owner's manuals it says that for high altitude, high sustained speeds, or towing, that a higher viscosity is
required for adequate protection.
I'm considering trying a 40 weight, as well as a long term test using -20 -30 and -40 weights with UOA on all three.
Makes a lot of sense for Ford to switch the spec to 5w30 for the 6.2 V8, i.e the engine in the Raptor, these engines are driven HARD and often they are supercharged, i wonder what the new Ecboboost Raptor will spec as it's a specially tuned and beefed up engine
