Originally Posted By: expat
My gauges are Smiths, they require 10v, but they originally received 14v alternator out-put that was regulated on and off via a bi-metal contact to simulate a steady 10v.
Over the years those bi-metal contacts vary in their simulated out put.
Gauge lighting is full alternator power, regulated if need be, by a rheostat.
Why would a Buck converter not be suitable?
The voltage drop across the regulator X the current "through' the regulator is the power your regulator will have to dissipate as heat, so it most likely will have to be heatsinked.
Buck converters are switching regulators and unless they are filtered properly, will generate noise that will be sent throughout your electrical system, including the PCM.
I think what you really need is an LM317 adjustable regulator in a TO-220 package on a heatsink.
http://www.ti.com/lit/ds/symlink/lm317.pdfhttp://www.ti.com/lit/ds/symlink/lm317.pdf
If interested, I can show you how to determine the R2 resistance.
