So I have about 500 grams of Castrol HTB grease. It's a Bentone clay, high temperature bearing grease, NLGI 2, stable up to 200 C (390F).
OK, so obviously it's good for wheel bearings, and I know it does not play well with other greases, like lithium chassis grease.
I'm just looking for ideas for other places I can use it, not anywhere that would cause confusion, like where people would expect to find a lithium grease. Not instead of the proper grease when required.
What is it like with water ?
Could it be used as a type of anti-seize in non-critical, lower temperature applications ?
Just looking for some ideas of where to use it, since I have it and I'm not pulling many wheel bearings apart now days.
