Originally Posted By: firemachine69
Originally Posted By: tomcat27
A few years ago someone here posted a link to a document explaining the GM system in detail. for the most part, these systems are using an algorithym to calculate considering: miles, rpm, engine load, temperature, drive time, etc. The monitors have no idea what type of oil you are using and are not performing any type of oil analysis. I believe that Mercedes, and certainly others, have researched using actual oil condition monitors. IIRC, Volkswagen had an issue years ago because their OLM's were set to assume synthetic oil - which is commonly used in Germany - and here in the US many engines were ruined until the OLM was reprogrammed.
In my 2015 Outlander, the OLM is settable to five or nine months, based on type of oil used. It's somewhere in the manual how to do it, I don't worry about that though, run full syn OCI's from the dealership, and let them take care of the monitor. I go in when my little wrench oil change symbol comes on.
You don't worry about it and just come in when the little wrench comes on? The only rather huge problem with that is that if you don't actually open up your hood and check your actual oil level, you could be driving around for thousands of miles with your engine low on oil. And depending on what the manufacturer determines is "normal" oil consumption, that could mean 2-3 quarts low. Keep doing that and it will take rather big wrenches to keep you driving.
If you check your oil level periodically and go by the monitor, then yeah, everything should be ok, if not? You could easily end up replacing your engine before it reaches 50,000 miles depending on how much your engine consumes between changes. I know BMW is having all sorts of engine problems because of their oil change interval and customers who think they only have to worry about bringing the old car in when the maintenance light turns on.
