Been working on a late 90's Grand Cherokee and noticed something funny. The caliper bracket is built in to the spindle and the brake pad ears contact the bracket directly. There are no replaceable abutment clips on the bracket. You can install some on the pads themselves, but that does nothing to protect the bracket from wear.
As such, when replacing the brakes I noticed some notches starting to wear in to the caliper brackets/spindles. Which as I said are not readily replaceable- you would have to remove them from the ball joints and all. I've tried using the little clip-on abutment shims on the brake pad ears but that only leads to the caliper seizing and frying the brakes.
Do any other vehicles have this type of setup? Is there anything I can do to prevent further wear on the spindle/caliper bracket? Looks like I have to run without any abutment clips to prevent seizure...
