- Joined
- Nov 29, 2009
- Messages
- 7,268
I'm not sure how much warming up is needed when it's around 90 degrees outside, but I notice lawn care companies startup and run their equipment straight to full throttle as soon as it starts and they don't ever seem to have a problem. Usually in the winter if you don't let them idle for a minute or so it will bog down and stall, but these engines generally startup and run fine with no bogging in the summer. Today I bought a new blower and I notice with every piece of equipment I guy the mechanic takes it in the back fills it with fuel and runs it straight to full throttle. My guess is to make sure the carb settings are right? I'm not sure because most times it won't need an adjustment until it's good an broke in, which is after about 100hrs. A lot of ope will stall if you let it idle when first started especially once they have a good amount of hours on them so I've always just stuck to not using full throttle until they've been running for a few minutes. Opinions? Am I worrying about something that doesn't matter? Maybe in the summertime cold seizure isn't an issue?
