Back in the 80s, I was part of a car pooling group of 3. We all worked at the same place so it was easy. We bought an old ragged out base model '70 Camaro with a 6 cylinder and 3 speed trannie to drive to work. Miles unknown when we bought it. As the years and the miles piled on, oil consumption picked up considerably. Working as diesel Thermo King mechanics, Rotella was easily available and we used it.
Liberally.
When the car started going through the Rotella too quickly, we switched it over to 75w-140 and drove it for two more years that way, before basically throwing the car away. Needless to say smoke was ever present and I'm sure we didn't meet any applicable state or federal regulations of any kind. But if fulfilled it's function until we moved on to '73 Bonneville with only 120k on it.
So an engine can run reliably on straight hypoid gear oil, if you're not too concerned about your ppm fe or exhaust emissions. That was the most carefree driving of my life; just add gas and about a gallon of oil every 100 miles or so.
