Originally Posted By: Jarlaxle
Originally Posted By: A_Harman
Originally Posted By: MNgopher
Normal stuff in high altitude areas and generally works fine where 87 octane is used and you will remain at higher altitude. Won't use in a turbo vehicle, but in NA its fine.
Agreed. Modern turbocharged engines are controlled to achieve a certain manifold absolute pressure before opening the wastegate(s). So if it is running at altitude, the turbo will spin faster to make higher boost pressure, and the engine will make the same power as it does at sea level. Not a good time to put lower octane fuel in.
How many turbocharged engines made in the last 20 years DON'T have knock sensors?
None. But then it will retard spark, and the engine will lose performance.
Long term running with retarded spark may cause excess exhaust valve seat recession.
