That PDF file from Hy-Per Lube is misleading and demonstrates the pitfalls of having just a little knowledge about a subject.
Yes, distilled water is devoid of metallic minerals and yes it can leach those metals from engine internal parts but this is at the parts-per-million range and will never, ever be noticeable in any way. The only time this becomes an issue is when you have fresh, new distilled water continuously flowing over metallic surfaces (as in industrial piping or in the still itself), not in a closed system. Once the water in a cooling system becomes saturated with metals (at a very, very tiny level as compared to the massive bulk of an engine) then it will stop leaching metals and become passive. There is
no way this is an actual issue from a practical standpoint.
Besides, soft water won't make any difference. Sure the calcium and magnesium ions are replaced by sodium ions, but those metals aren't the ones we are talking about in an engine. The water is still just as able to dissolve iron and aluminum as it was before softening, and in fact soft water is now able to dissolve more calcium and magnesium (and more iron as most softeners remove some iron) since they were removed and replaced with sodium ions. It's not a static equilibrium - remove the "hardness" minerals and replace them with sodium ions, and the water is now able to re-dissolve those removed ions once again. That PDF file that tries to make a distinction between "stripping" and replacing ions is meaningless. No matter how they are removed they can still be put back.
But in the end it doesn't mean anything. We are still not talking about the metals in an engine and the truly minuscule amount of metal dissolved in a closed cooling system is not even worth mentioning. It would likely take thousands and thousands of coolant changes to ever see any effect. Besides, coolants contain passivation compounds to protect the interals anyway.
Originally Posted By: mctmatt
Just as Colt 45 said when you read the bottle of Purple Ice and other coolant additives they all recommend to use plain drinking water and not distilled. Here is a link from HyperLube Super Coolant
http://www.hyperlube.com/mc_images/category/8/distilled_water_in_cooling_systems.pdf
Just a quick question did you flush the coolant or did you pay to have it flushed. I paid to have mine flushed several years ago and the shop did a very poor job. Less than a year later I needed to do the job again but this time I did it myself and have never paid anyone again for this job. Now it is just drain and fill .
