Originally Posted By: linksep
After posting and reading a few responses I went and dug the filter out of the local and state approved filter disposal receptacle... I opened it up by hand and tore several pleats worth of material off then tried to shine a very bright flashlight through it (while pulled flat...no pics, not worth taking pics). I could see some light through some portions of the media, but it appeared more plugged than I would have expected (I did NOT attempt to wick or squeeze most of the oil out of the filter element).
I did open the housing and inspect the new filter with about 130 miles on it and I was able to see a LOT more light through it using the same flashlight, also there were no visible tears or other defects.
I think I'll inspect this filter every 2500 (which is about once a month... I might not be able to check it that often) and either replace at 10K with the oil or try to go two OCI again if it's not blackout dark at 10K or 15K during regular inspection. I really don't want to have to do math and/or take notes when to do an OCI or FCI... OCI at 160K, 170K, 180K is easy enough for me, FCI at same or even number I can handle [when dropping 4 zeros for you OCD AR types] (160K, 180K, 200K).
Hello,
We do not recommend using this filter past 15k miles, hence the statement on the box that is suitable for up to 15k oil changes. That said, there are many variables including bypass valve function, general engine and cooling system cleanliness, pcv operation and more. These are the reason there are oil change monitors. Because of the way this filter snaps into the cap, I also would remove it so often, not what it was designed for. If you want us to evaluate the original and let you know what we find, you can mail it to me. Just send me an email at my framgrp address and I will send shipping instructions.
