Hi guys,
I'm at 50,000 miles on my Tacoma now, and am probably going to be doing an oil change this weekend. I've been doing them on the recommended 5,000 mile OCI per the manual. I've always wanted to extend this to 10,000 miles or 1 year, but I don't know why only my specific engine hasn't been approved by Toyota for this OCI.
Per this link -
http://toyota.custhelp.com/app/answers/detail/a_id/7604/~/what-are-the-oil-change-intervals-using-synthetic-oil%3F
"Only Toyota vehicles in which 0w-20 synthetic oil is required (except for the 2TR-FE and 3UR-FBE Engines*) have been approved for extended oil change intervals of 10,000-miles/12-months. (However, you should continue to check the oil level regularly and top off if needed. That will help your engine get the full benefit of synthetic oil.)"
"*The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85."
Does anyone know if there is a good reason why my engine hasn't been approved for this?
My Tacoma is the 4 cylinder 2TR-FE. Since I am out of warranty now would it be ok to extend the OCI since the engine requires 0w20 anyways? I usually use TGMO 0w20 or M1 AFE 0w20 and an OEM filter.
Thanks,
Per this link -
Thanks,
