Hi Merkava,
Here's a distillation of my research about SD situation.
1. Wound to stop is a fallacy. Even police and military have to shoot Center of Mass, because a torso is MUCH MUCH easier to hit. Get it in your head that you need to STOP THE ATTACK. Whatever happens to the attacker isn't your problem or issue.
2. You can't miss fast enough to win a gunfight.
3. If you don't put him down fast, it will be hand to hand in about 2 seconds. Check out the FBI's 21 foot mad dash attack.
4. Pistols are only good if you practice HOW YOU WILL FIGHT!!!
5. My recommendation is a pistol caliber carbine; from Hi-Point, and get the extra mag kits and practice, practice, practice.
6. Find a Criminal Defense lawyer. Ask your lawyer for referrals. Spend a half- hour and go over how these things are handled in your jurisdiction, what to expect from the police, what you should say/ not say.
7. Hollow point ammo that hits a person will generally not leave the body. If you miss, I can tell you that a 357 magnum will go through one plaster wall, penetrate a 2nd; and fall onto the floor.
