Kind of a strange thread here. The OP started out wanting to use waste oil spread out on his driveway, creating a lashing out of pro environment concerns. He then switched to using a commercial product, but many did not catch on. It will be interesting how his homemade application will compare to commercial work.
Village? (mjoekingz28): No, not the African kind. This is just one form of administrative classification very common in some parts of the U.S.:
https://en.wikipedia.org/wiki/Administrative_divisions_of_Wisconsin
- For those not familiar, the process Shoz is doing is called
chip seal paving:
https://www.google.com/#q=chip+seal+paving
- Finally, I'm not sure why the OP initially confused chip seal with used oil for the application. Used oil might actually hamper the adhesion of any product AND it is certainly not a good thing to do environmentally:
http://homeguides.sfgate.com/used-motor-oil-pollute-79336.html
"Used motor oil contains numerous toxic substances, including polycyclic aromatic hydrocarbons, which are known to cause cancer. In addition, tiny pieces of metal from engine wear and tear, such as lead, zinc and arsenic, make their way into lubricants, further contributing to the polluting potential of used motor oil. Motor oil is exposed to heat and oxygen during engine combustion, which changes its chemical makeup. (See Reference 2, Pages 6 and 7) Because spent motor oil is heavy and sticky, and contains an extensive concentrated cocktail of toxic compounds, it can build up and persist in the environment for years."
My goodness, I remember when it was common to just dump used motor oil on the ground after an oil change.
