I've used my rigid wet/dry shop vac, and a squeeze pistol type nozzle on a garden hose. With the car facing downhill i spray water and vacuum at the same time, You can soak spills first with simple green or some other cleaner.
For the rear, i have the car face up hill and do the same, keeps the water from running under the front seats where i can't vacuum it as easily
