*sigh* I remember my parents 1987 Chevy Astrovan. It would only start in P or N, no issue with that. But I didn't have to step on the brake to crank, and once started, I could drop into drive without having to step on the brake either. Just drop right down. None of this fancy "brake to shift". Also, once started, you could pull the keys out of the ignition (for no good reason other than because I could).
First couple of vehicles I owned were late 80's vintage and I would disable the clutch interlock switch. On those I would shift to neutral and start, no foot on brake or clutch required.
Today I've thought of disabling those switches/interlocks, but I'm sure the first time I loaned out the vehicle I'd regret it. I still don't like 'em. Necessary nuisance.
Have to admit, I've grown fond of the starter in my truck--I can reach in with the key, give a quick flip, and walk away--it'll finish cranking on its own. I kinda like that feature, as I can do that in cold weather and go about cleaning off the truck. Just reach in and start. What a concept.
