Sta-Lube Moly-Graph Grease
JHZR2
Staff member
New Jersey
Anyone use this stuff? I was looking for a high moly grease in a 3oz tube and found this at my local NAPA.
It is Lithium 12 Hydroxy Stearate, fwiw, but I guess that's fully compatible with Li complex, no?
Anyone know the moly percentage?
One site claimed 3%, one msds claimed 0-1% for both moly and graphite... But no up to date answer.
I emailed them (CRC) recently as I also have a 3oz tube 3 pack, mine purchased from HF. I was particularly interested in moly % and U Joint use. Here's their reply.
"Thank you for your interest in our Moly Graph Grease. The product is approved for use in non-disc brake wheel bearings and for U-joints. The percentage of Molybdenum in the grease is 1%."
Interesting. So I guess the MSDS I saw was right then, with 0-1% Mo and 0-1% graphite.
Thanks!
No, but maybe this is 'something' for you.
Sta-Lube
EP moly-grapgh
Multi purpose grease
I got it about the time I joined this site.
Part no SL3141
Lithium 12 hydroxy stearate
Black
Nlgi 2
360f min drop point
Excellent water resistance
Timkin ok load 40lbs
Ingredients (in order) under the Warning tag
Mineral oil (heavy) 64741-96-4
Lithium soap 7620-77-1
Antimony dialkyldithiocarbamate 800983-5015 P
Calcium dinonylnaphtlene sulfonate 57885-77-3
Made in USA
